Carbs gushing gas
Carbs gushing gas
After 7 years of zero problems, my carbs both started gushing gas out the sides. It was running fine before this. Did both my float valves just give up?
Re: Carbs gushing gas
Turns out my cover plates for the jets were simply loose.
While you're there: you may want to replace the carb gaskets when you take off the covers. They're just o-rings that you can find at any hardware store and will save you from future fuel spewage.
