View unanswered posts | View active topics It is currently Sat Oct 21, 2017 2:26 am
Reply to topic  [ 12 posts ]
 Top carburetor gasket too small
Author Message
Post Top carburetor gasket too small
We have the SAV small idle screw carburetor repair kits. We found that the top gasket that goes under the cover is too small, all of the holes won't align with all of the ports. SAV said all their gaskets are the same. Do these gaskets need to be soaked in something to expand and fit the ports?
_________________
1971 Pinzgauer M710, all stock including 245-16 Maloya tires, taken off and stored for show
Tue Apr 18, 2017 5:23 pm
Profile
Post Re: Top carburetor gasket too small
Do you have a non standard carb on the rear??Are they exactly equal?
_________________
(2) 1968 Haflingers One For Sale
1979 Mini Cooper Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Current Company Cars
2017 MKT
2018 F-150
Wed Apr 19, 2017 9:07 am
Profile
As far as I know they're exactly equal. I'm not with the Pinz now. I'll check with my Brother and see if he found the same problem on both carbs.
_________________
Wed Apr 19, 2017 9:10 am
Profile
My Brother said the same problem on both carbs, top gasket too small.
_________________
Wed Apr 19, 2017 9:41 am
Profile
interesting! I have never had this happen. I've had to modify gaskets to add a hole, but never had an issue with it being too small.
(I really want to make a crude joke right now)
_________________
2017 MKT
2018 F-150
Wed Apr 19, 2017 10:31 am
Profile
You may want to soak the gaskets for a while so they expand and fit right. Not sure what to use as a liquid. Jim made mention of this one time.
Wed Apr 19, 2017 7:02 pm
Profile
I saw that somewhere too, but couldn't find it again. It seems like one choice was brake cleaner?
_________________
Wed Apr 19, 2017 7:13 pm
Profile
For cork gaskets steam them, once soft then put them in place and allow to dry.
This is typical of the valve cover gaskets, I had a set that shrunk and needed to
be reshaped -- as per Jim L's instructions. I presume your gasket is off by only
a small amount and not a more than normal shrinkage would explain?
_________________
Puller: 710K 2.7L EFI
Wed Apr 19, 2017 8:11 pm
Profile
I think it might be shrinkage. Most of the ports and holes lined up, but one very small port didn't line up at all.
We do have a hand steamer. Any tricks to that?
_________________
Wed Apr 19, 2017 8:23 pm
Profile
You want to flood that gasket with "live steam" Older movie buffs will pick up on that one :D
I'd use a Stove top steamer that fits inside a pot a flood those gaskets like your steaming a
pot full of Mussels. Give it 5 to 10 minuets and see they are soft and pliable.
_________________
Wed Apr 19, 2017 8:46 pm
Profile
Well we dodged the bullet this time. When I told SAV about the small gaskets, they sent me two new ones. The new ones fit perfectly. Although the ones that were good from SAV and the ones in the kit from SAV are reportedly the same gaskets according to SAV, the ones in the kit had shrunk.
_________________
Sat Apr 22, 2017 9:30 pm
Profile
I used hot water... just left them soaking for some time. Cant remember how much... until they fit well! I installed them slightly wet...
_________________
Jerome
CRJ Driver
Mon May 15, 2017 3:23 pm
Profile YIM
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
