View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:17 pm
Reply to topic  [ 2 posts ]
 Found the problem
Author Message
Post Found the problem
Replaced fuel line from tank to filter solved cranking without starting issue. Someone then told me to add a quart of automatic transmission fluid to full tank of gas. Is this helpful or will it cause more problems. I appreciate your opinions. Zig
Mon Dec 04, 2017 11:59 am
Profile YIM
Online
Post Re: Found the problem
Not a good idea to add ATF to gas, you don't want the byproducts of burnt
Auto Tranie fluid in your cylinders and on your rings. There are additives
specifically designed to clean the engine, I'd look into Lucas products.
_________________
Puller: 710K 2.7L EFI
Mon Dec 04, 2017 1:26 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
