accelerator pump failure?
wanderer
Post by wanderer »
while trying to sync my carbs i noticed the front carb was no longer getting fuel, i have had this problem before, the accelerator pump came apart inside the carb, i replaced both with new parts from swiss army vehicles, one of which has failed again. is this a common occurrence, is it just poor design? I would hate to have to keep replacing these every year.
would like to know if anyone else has this problem, thanks
-JP
...and now the fun part.
1981 712 amb
Re: accelerator pump failure?
This probably doesn't help much but I've never had one fail. I have had a couple wear somewhat so they no longer pump as well. Try reaching our to Jim LaGuardia for some ideas.
waterdog
Paraguay
Post by waterdog »
what would be the main job of the accelerator pump in the carb ?? im having trouble on sudden-quick press on the gas pedal the truck DIES! , but accelerates fine on progressive press on the gas pedal .. i was thinking on the carbs pumps :roll: :roll:
1985 710MS
1985 712MK
David Dunn
Post by David Dunn »
waterdog wrote:what would be the main job of the accelerator pump in the carb ?? im having trouble on sudden-quick press on the gas pedal the truck DIES! , but accelerates fine on progressive press on the gas pedal .. i was thinking on the carbs pumps :roll: :roll:
And you now know 1st hand what the accelerator pump is for. :lol:
During quick acceleration, the carb's suction lags far behind the engines demand for fuel. The pump is a mechanical method to meet that demand
waterdog
Paraguay
Post by waterdog »
Thanks!!! I thought so,,, : :D
1985 710MS
1985 712MK
Post by pinzinator »
I think that ethanol eats up the rubber plunger seal. That part is shown here- http://www.pinzgauer.com/showdetails.ph ... 122085120/
You only need the rubber part, I don't see that listed separately. Call them and see if they have just that part. Installation is easy.
