Carburetor shaft seals
boeing7873
Argentina
Post by boeing7873 » Wed Nov 29, 2017 8:41 am
Do carburator shafts have seals? I do not remember seeing anything non metal in the shaft ends. Thanks.
JC
Jerome
CRJ Driver
Hotzenplotz
Austria
Re: Carburetor shaft seals
Post by Hotzenplotz » Wed Nov 29, 2017 12:00 pm
JC
My original carburetors were series 1 and had no seals.
I bought used series 2 carbs with identical throttle blocks, and there were seals on the shafts.
item 5 on the pic are the shaft seals part-Nr 7121085401
I refurbished both pairs last winter, and both got seals
Albert
boeing7873
Argentina
Post by boeing7873 » Thu Dec 14, 2017 11:17 pm
Are these seals made of what material? Is it some kind of rubber or plastic? Do these fail often? Not really in the mood to remove the carbs again.... :(
Jerome
CRJ Driver
Hotzenplotz
Austria
Post by Hotzenplotz » Mon Dec 18, 2017 6:55 am
I honestly have no idea what the seals are made of.
I cleaned the old ones in petrol, and they did not dissolve...
later I decided to replace all gaskets including these rings
No idea if they fail often i replaced them "just in case"
Albert
