Carburetor shaft seals
Posted: Wed Nov 29, 2017 8:41 am
by boeing7873
Do carburator shafts have seals? I do not remember seeing anything non metal in the shaft ends. Thanks.
JC
Re: Carburetor shaft seals
Posted: Wed Nov 29, 2017 12:00 pm
by Hotzenplotz
JC
My original carburetors were series 1 and had no seals.
I bought used series 2 carbs with identical throttle blocks, and there were seals on the shafts.
item 5 on the pic are the shaft seals part-Nr 7121085401
I refurbished both pairs last winter, and both got seals
Posted: Thu Dec 14, 2017 11:17 pm
by boeing7873
Are these seals made of what material? Is it some kind of rubber or plastic? Do these fail often? Not really in the mood to remove the carbs again....
Posted: Mon Dec 18, 2017 6:55 am
by Hotzenplotz
I honestly have no idea what the seals are made of.
I cleaned the old ones in petrol, and they did not dissolve...
later I decided to replace all gaskets including these rings
No idea if they fail often i replaced them "just in case"
