Fuel Pump Block-Off Plate
Posted: Thu Aug 23, 2018 7:00 pm
by lifefloat
<t>Hey All...….…<br/>
First and foremost...So glad to not only own a Pinzgauer, but so glad this forum exists as well. <br/>
<br/>
Quick question to those in the know. <br/>
<br/>
My truck had an electric fuel pump in it when I got it. I could tell a long a story at this point, but the short of the matter at hand is this:<br/>
<br/>
I want to remove the manual pump and block off the port it sets on.<br/>
<br/>
I pulled the pump. Push rod was not present. <br/>
<br/>
<br/>
Any valid reason to keep this non-functional pump on the truck? <br/>
<br/>
<br/>
A flat piece of stock and this port can be blocked is my opinion. Sage advice is what I seek. <br/>
<br/>
Thanks</t>
Re: Fuel Pump Block-Off Plate
Posted: Thu Aug 23, 2018 7:02 pm
by lifefloat
That post looked terrible. Ugh
I'll get the hang of this forum soon though.,patience.
Posted: Thu Aug 23, 2018 7:48 pm
I don't know if I have sage advice or not but I do recall that others who have switched to an electric fuel pump did in fact fabricate a block-off plate. Don't forget the gasket.
Posted: Thu Aug 23, 2018 9:20 pm
by 4x4Pinz
I have been running an electric pump for years. I chose to keep the manual pump and carry a rebuild kit for it as a back up. I have a 24" prefer of fuel hose connected to the inlet and outlet that I filled with fuel to keep things wet. Never had to use the rebuild kit for myself but have rebuild s few manual pumps in the trail.
Posted: Fri Aug 24, 2018 8:15 am
by pinzinator
VW parts sites have a block off plate that will work, get the one for the older air-cooled engines. Try the Samba site, I think they have it. They also sell a turn-signal switch that works perfectly, order the one for a '71 bus.
Posted: Fri Aug 24, 2018 4:02 pm
by 4x4Pinz
pinzinator wrote: ↑Fri Aug 24, 2018 8:15 am
The switch is good to know
Posted: Sat Aug 25, 2018 6:36 am
by lifefloat
Thanks for all the replies concerning the fuel pump block off plate.
The VW parts source is not something I would have thought of. Did a little searching and found two different plates that look like they would work just fine. One for $6 and another made of billet aluminum for $13.
https://www.jbugs.com/product/31-3011.html
Going with the billet. A little hidden bling.
I'll follow up once I receive it and let everyone know if it fits correctly.
Posted: Sat Aug 25, 2018 6:45 am
VW plate is what Jim L has been using for years
