Flywheel position for balance
Posted: Fri Sep 13, 2019 8:05 pm
In my quest for removing all leaks I removed the flywheel to change the crankshaft oil seal (which was completely dry). When I removed the flywheel, I marked one tooth and a corresponding location in the engine timing gear cover plate. Then I figured that the leak came from the gasket between the block and the timing gears cover plate, so I removed it, and proceeded to wash it, that included washing the mark for the position of the flywheel.
Now I can only guess its original position. Is the flywheel balanced with the crankshaft or can I assume it can take any position?
Many thanks for any input.
