Choke (fuel enrichment) screw up?
Posted: Sun Apr 05, 2020 1:25 pm
by acurtis
So I have been working on getting my 73 710 back on the road after years of sitting- so went through the "red death", then added the solid state ignition module, then rebuilt the carbs, replaced one shut off solenoid. The problem is i think I messed up the chokes when i put them back together. Initially i thought it was a float height problem (yes, on the list)
It starts up, but idles crazy fast with choke off, when i open the choke it slows a little, but still way to fast, It also sputters when when you give it some gas. I'm getting ready to open up the chokes and look- (I assume I put them in both the same way)Is it possible to put the plates in backwards or upside down or just "in wrong".
so................... looking for any guidance on the set up.
Re: Choke (fuel enrichment) screw up?
Posted: Mon Apr 06, 2020 5:07 pm
by Dave King
Yes, you can put put the fuel enrichment plate in wrong. If you look at the plate side, in the center is a half round proud section of the round pivot. If you look at the carb side, there is a V depression in the center. This allow the plate to only rotate less than 25 degrees of rotation.
Posted: Tue Apr 07, 2020 7:49 am
by Hotzenplotz
We discussed that topic in the german forum some time ago.
Norbert kindly posted that pic
hope that helps
Posted: Wed Apr 08, 2020 11:35 am
by whitesik
A close but a little off topic problem. The nut holding the fuel enrichment plate frequently comes loose on my front carburetor. You can imagine the result. Is there any predisposing reason for this to occur and is it ok to add a little thread locker? Thanks all!
Posted: Wed Apr 08, 2020 12:30 pm
by pcolette
The nut you're referring to is indicated by the red arrow if I understand correctly.
I've used a lock washer and had good results. You could also use a distorted-thread nut if you prefer. I don't see a problem with using thread locker either.
Posted: Wed Apr 08, 2020 8:12 pm
by whitesik
yes! That's it. Thanks!
