Runs at idle but won’t rev
Posted: Tue Jan 26, 2021 7:15 pm
So I recently purchased a Pinz and was running great until I accidentally left the ignition on and fried the coil and pertronix module. Replaced both the coil (flamethrower 3 ohm) and the module and after some time turning over the motor it fired.
Sat and idled fine for a few minutes but when trying to give it gas it wanted to die. I shut it off and just after it had trouble starting again. Everything was running fine up until I fried everything the other week and thought it would return to normal after replacing them.
I’m curious if maybe the ballast went bad too after leaving the ignition on or what it may be. Seems to be getting plenty of fuel. And the spark looked strong when testing it. Would like to know what I may be missing or what else to look for. Thanks
