torquing carb to manifold
Posted: Sat Sep 24, 2022 7:20 am
by 2013cossj
Is there a need to semi tighten all 4 nuts, then torque down further in a certain pattern? Are the unique pinz washers required?
Thanks in advance.
Re: torquing carb to manifold
Posted: Sat Sep 24, 2022 8:44 am
by rmel
The serrated (or ribbed) lock washers are the best to use as they
lock well and without marring the surfaces as a split lock can do.
But in a pinch a split lock washer can be used.
I snug these nuts up with a box wrench going all around tightening
gradually as the gasket is very thick and compresses -- so don't over
tighten. Go back in a few months after several temperature cycles
and re-tighten if necessary. You just don't want a vacuum leak so
no need to be super tight.
In any case it's too tight to get a socket on several of the nuts esp.
with the tin on the front carb so torquing is not practical.
Posted: Sun Oct 02, 2022 12:10 pm
by Stumbler
Although everything you read says no sealants or locking stuff is necessary on the carb or throttle body, I found (the hard way) that those bolts have a tendancy to loosen and then your system leaks right between the throttle body and the carb, which makes it run rough and stumble. Then it becomes a couple hour long ordeal to remove everything, tighten the bolts to the correct torque, and put everything back.
After the second time they came loose I used a little blue Loctite on them and torqued exactly to spec and my carbs have never come loose again in the last 5 years.
Posted: Thu Oct 06, 2022 8:23 am
by Hotzenplotz
I use nuts from a tuning shop in Germany.
They offer M8 nuts for 10 mm spanners.
https://www.universalauspuff.de/zubehoe ... 2154g.html
This allows me to torque the carbs to 20 Nm
Posted: Thu Oct 06, 2022 9:58 am
by rmel
For the record, the lock washers are "Schnorr" serrated. They lock well and are specifically designed to lock in the presence of vibration.
You can source them from Bell Metric (and other outlets).
https://belmetric.com/steel-s-series-up ... rr-washer/
I'd recommend them over split locks or flat washers.
