Hard starting hot
Hard starting hot
My Pinz takes a lot longer to start when it is hot. It starts instantly when engine cold regardless of air temp. Takes a bit of cranking when hot. Ideas?
Jim Chance
710M
710M
Re: Hard starting hot
Heat may be affecting the coil.
Did not think of that.
Jim Chance
710M
710M
- David Dunn
Check your charging voltage. If something's wrong with the voltage regulator or the alternatorr and gives out over 30 volts that will overheat your coil
What is the interval between starts? Long enough for the fuel to evaporate in the bowl in hot weather? Are you using the "choke" in hot weather; full? half? There are many variables.
75 Swiss 710K
W9YG
W9YG
If I leave it off just a minute or two it is fine. If I leave it off an hour it is fine. In between it is likely to be balky.
Jim Chance
710M
710M
