I have a napa belt on now. New it has to be run with no adjusting washers or it slips. Is this typical when using replacement part rather than original? Is there a replacement thta works better?
thanks
fan belt
I've also got the NAPA 4L41W belt which was listed on the replacement parts list. Mine works fine.
Are you saying you've got no washers between the shives and all the washers on the outside? IIRC, that would adjust for max. tightness of belt. If you're still loose then, I'd have to assume you needed a shorter belt. Not sure why that might be. It does not sound typical.
Putting all the shim washers between the shives, and none on the outside would make the belt looser still.
fan belt
that is the belt I have on...and yes no washers between the cheeks of the sheave. I will try one of the other replacement belts
- David Dunn
There needs to be some deflection in the belt. If it doesn't, you'll overstress the alternator's bearings. With proper belt tension, and you have the belt slip, it could be the bearings are going bad ( not allowing the alternator to spin up as quickly as the engine).
Also, if the aftermarket belt is different than the original, it may not be making proper contact with the pulleys. I had this with a Supacat, where a replacement belt had a slightly different pitch and thickness where I couldn't get a proper adjustment. And oddly enough, it too has a split pulley .
