Pinzgauer Questions
Pinzgauer Questions
Hey Guys,
I am not too familiar with how Pinz's are set up. I was wondering what the hose attached to the air box is used for? It is the black hose that is roughly 1.5" in diameter.
Couldn't figure out what its for! Thanks in advance! - Jack
-Jack Miles
Unimog 404 Doka Hardcab Turbodiesel
If you are referring to "GR 30 05" as pictured on this web page
http://www.swissarmyvehicles.com/parts. ... view=01-35
it provides warm air from exhaust shroud aiding performance when engine is cold.
Ed
Ed
Yeah that is probably it. It did look like it was connected to some sort of heat exchanger, didn't look too close though. Where does it pull the heat from?
I have a suspicion that this would only be effective in colder climates (ie; not Florida). What does anyone else think?
-Jack Miles
Essentially correct however post Pinzgauers are equipped with what I would consider a semi automatic diverter. The flapper being weighted in such a way that at low intake volumes / velocities the diverter causes warm air to be drawn. As the volume / velocity increases cooler air is drawn. The diverter can also be locked (latched) in the open position (cool air only) for summer (above + 30 C (86 F)), use. There is also a thermostatically controlled version that saw limited use don’t know if any of the military trucks were equipped with it. Page 55 of the repair manual states “Only in case of temperature being permanently above + 30 C (86 F) , the hot air flap is to be arrested in the open position”.Pinzgauer Pete wrote:..there would probably be a diverter valve before it that opens after reaching normal operating temperature
Ed
Here's the thermostatically controlled regulator from SAV. I didn't see one on EI's website. http://www.pinzgauer.com/showdetails.ph ... 121195019/
everything in the Pinz is designed to endure severe conditions, and is waterproofed..there is however a recommended water fording depth that is listed on their specification sheet, but if you look at any of the videos on youtube you will see literally hundreds of examples of owners far exceeding those guidelines. For me personally once I see water coming into the cab area I would say its time to seek higher ground!!! LOL
710M
710M
