Petronix v original
Engine troubles? Try here.
JimmyC
Petronix v original
Post by JimmyC »
My ignition has been changed over to the civilian petronix. When this is done, is the distributor itself changed or do they keep the original Bosch?
Jim Chance
710M
Re: Petronix v original
Pertronix module is installed into the original Bosch distributor after removing the points and disconnecting the condensor.
kdiqq
Post by kdiqq »
JimmyC wrote:My ignition has been changed over to the civilian petronix. When this is done, is the distributor itself changed or do they keep the original Bosch?
Which part are you talking about? The shaft of the distributor is the same. The points (under the cap) in removed and replaced with the Petronix ring and pickup. Then a new cap and adapter for that cap are bolted on. With the new cap comes new wires. With new wires comes new plugs. Factory coil is used.
1977 Austrian 710M
JimmyC
Post by JimmyC »
I meant the housing, shaft, mechanical advance
Jim Chance
710M
JimmyC wrote:I meant the housing, shaft, mechanical advance
not changed. remember to sand the bottom of the civilian rotor. Timing 3-7mm btdc.
