idler arm.....
Posted: Wed Oct 21, 2015 9:00 am
by waterdog
i was working on this leak on the front differential where the idler arm pivots, and the books calls for a BEARING WASHERS,that was a non-existent part on my pinz, there was only a NYLON WASHERS and a real thin metal washer, is there a way that this pinz came with no BEARING WASHERS?? i was hoping to find residues of a bearing washer but there is none, just nylon washers top n bottom,, diagram is GROUP 5-05 i have a 1985 pinz and i dont know if the leave the bearings out for this year or ?????? thanks!
Re: idler arm.....
Posted: Wed Oct 21, 2015 10:31 am
by Hotzenplotz
Hi waterdog
let us refer to a picture from the manufacturer
from
http://www.puch.at/en/spare-parts/pinzg ... ng-damper/
here you find items 10 and 22 called brag link; sav has these items as idler arm.
they are held together by scew 11 and nut 12. The bearing washers 18 are designed to carry the load , and to adjust the clearance beween these arms and the bearing sleeves 21 they use washers 19 available in different thickness. (only visible in german ...)
EINST.SCHEIBE 40/25.5/0.3 Artikel-Nr 7581430031
EINST.SCHEIBE 40/25.5/0.4 Artikel-Nr 7581430041
EINST.SCHEIBE 40/25.5/0.5 Artikel-Nr 7581430051
they are 0.3, 0.4 and 0.5 mm thick. You can have combinations of rhese washers if needed, but they all are solid metal.
Hope that helps
Re: idler arm.....
Posted: Wed Oct 21, 2015 4:23 pm
by undysworld
If it's to eliminate the up/down movement of the arm, yes, you adjust with shim washers. I believe I've still got a few, as I had to buy them in a bulk pack of a dozen or so. I searched high and low all over the city, but nobody uses shim washers anymore. I got them from some distributor out of Chicago.
If you think it's best, I can search to see if I've still got them and could mail you some. But of course, it's a long way...
Re: idler arm.....
Posted: Wed Oct 21, 2015 5:01 pm
It's not any closer, either, but McMaster-Carr has shim washers that might fit:
http://www.mcmaster.com/#standard-shims/=zgv8pa
Re: idler arm.....
Posted: Wed Oct 21, 2015 8:43 pm
Haflinger translation calls them bearing washers too
I thought I was missing something but it is either just the translation for shim or they are "bearing" the weight as previously stated by Hotzenplotz
Re: idler arm.....
Posted: Wed Oct 21, 2015 9:59 pm
by waterdog
Thank you very much folks, now i got it clear,!!! I though it was some kind of METAL BEARING OR ROLLER,,, washers i can get them custom made same material like the originals,,,,thanks again!!!
Re: idler arm.....
Posted: Thu Oct 22, 2015 2:49 am
by Hotzenplotz
TechMOGogy wrote:Haflinger translation calls them bearing washers too
the top shim is bearing the weight of all moving parts in the steering mechanism...
have a small amount of grease between the shims
Re: idler arm.....
Posted: Thu Oct 22, 2015 11:44 am
waterdog wrote:Thank you very much folks, now i got it clear,!!! I though it was some kind of METAL BEARING OR ROLLER,,, washers i can get them custom made same material like the originals,,,,thanks again!!!
Not sure what size you need (as I did my Hafi vs Pinz) but try these guys
Fast shipping and all sizes vs trying to make them
https://www.thebearingcompany.co.uk/sea ... rch=Search
Re: idler arm.....
Posted: Thu Oct 22, 2015 2:05 pm
by undysworld
Hotzenplotz wrote:the top shim is bearing the weight of all moving parts in the steering mechanism...
I don't think this is true, or at least it's not how I would describe it.
There is no particular "weight" being borne. The idler arm simply swivels as the steering moves side-to-side. But the tie rods connected to it are not mounted in the same plane. The steering input is higher, and the hubs are lower. Because of this height difference, any tie rod movement (whenever you turn the steering wheel, the axles move up and down, or the tires turn side-to-side) also imparts a slight up/down movement on the idler arm. The shim washers are used to adjust and minimize this up/down movement yet still allow the idler arm to swivel side-to-side.
If the shims wear out, you hear a clunk noise when you hit a bump as the idler arm moves up and down.
We agree on the grease.
Re: idler arm.....
Posted: Fri Oct 23, 2015 9:23 am
by waterdog
correct, that is how i found out, i heard a clunk noise on bumps and found the leak , now replacing all tie rod ends, o-rings and washers...hope i can stop the leak and noises.....
Re: idler arm.....
Posted: Fri Oct 23, 2015 10:46 am
by Hotzenplotz
Replacing o rings and washer will not be enough, I'm afraid.
There is a large o ring behind the RELAY SHAFT HOUSING Art-Nr 7101433151
if you find oil there you must find the source, and I guess you will have a leaking shaft seal ring behind the speedometer pinion.
Re: idler arm.....
Posted: Fri Oct 23, 2015 4:29 pm
by waterdog
sooo. where is the lubrication coming from for this speedo gear????
Re: idler arm.....
Posted: Fri Oct 23, 2015 5:31 pm
by Texas710
Doesn't the front diff do that Speaking about 091.02.05 (which is where my leak is)
Re: idler arm.....
Posted: Fri Oct 23, 2015 6:47 pm
by waterdog
in the picture group 03-15, the part #4 is not lubricated????
Re: idler arm.....
Posted: Sat Oct 24, 2015 3:13 am
by Hotzenplotz
waterdog wrote:sooo. where is the lubrication coming from for this speedo gear????
speedo gear takes a little grease when assembled, and is not connected to the oil of the diff
