clutch at edge of pedal
Post by audiocontr » Wed Aug 16, 2017 3:00 pm
My clutch feels like the engagement point is JUST at the edge of pedal release. Anymore and it will slip. Would a shorter clutch engagement pin improve pedal positioning?
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
1979 Mini Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Company Cars
2019 Expedition
2019 F-150
Re: clutch at edge of pedal
Post by Haf-e » Wed Aug 16, 2017 6:36 pm
would be worth trying - a few minutes with a grinder would tell... of course you would need to order a new regular one still.
Looks like there are three sizes - 152, 154 and 156 mm long - here is a picture of the longest one - a "two stripe" 156mm.
$42 new / $35 used from SAV
Do you know which one you have in there?
Post by 4x4Pinz » Wed Aug 16, 2017 7:28 pm
I stopped buying the cross referenced clutch and pressure plates because of this exact issue. You just never knew where the pedal was going to end up. The disk and plate I get from SAV leave the pedal at a normal feel.
We have also seen the pedal pivot point under the dash with excessive wear causing clutch pedal issues and of course poor quality or dirty fluid in the system.
Post by audiocontr » Wed Aug 16, 2017 7:36 pm
Not sure, but not the double striped one. That much i know.
I remember adding a dab with my welder when i first received the truck. It would not release enough to get into gear, and adding a bit moved the engagement point far enough that it felt normal. I guess its time to grind off my welded "dab" and give her a go.
1978 GMC Palm Beach
Company Cars
2019 Expedition
2019 F-150
Post by audiocontr » Wed Aug 16, 2017 7:38 pm
4x4Pinz wrote:I stopped buying the cross referenced clutch and pressure plates because of this exact issue. You just never knew where the pedal was going to end up. The disk and plate I get from SAV leave the pedal at a normal feel.
It was a bit sudden on the change. I'll swap out the fluid to be sure
1978 GMC Palm Beach
Company Cars
2019 Expedition
2019 F-150
Post by 4x4Pinz » Thu Aug 17, 2017 6:04 am
take a good look at the clutch pedal linkage. Have had to drive one home without the ability to use the clutch at all when the pedal assembly failed. Good thing there is no safety switch on the transmission and these trucks will start in gear.
Post by audiocontr » Sat Aug 19, 2017 7:26 am
Removed the bead i added to the pin. Wont go into reverse. My guess, the pin was 152 originally. I bumped it up to 154 and i was right where i was to start. I added a second bead to 156 and it helped. So to answer my original question... longer is better when the clutch is wearing
1978 GMC Palm Beach
Company Cars
2019 Expedition
2019 F-150
Post by audiocontr » Sat Aug 19, 2017 7:30 am
4x4Pinz wrote:take a good look at the clutch pedal linkage. Have had to drive one home without the ability to use the clutch at all when the pedal assembly failed. Good thing there is no safety switch on the transmission and these trucks will start in gear.
Everything looks good. There is more "dead" travel than i would expect, but to be honest, its not that i have to depress the pedal fully to the floor. All of the action is very close to the top of the release. I am amazed by how a couple of millimeters makes such a difference. Very different than my days of cable actuated clutches
1978 GMC Palm Beach
Company Cars
2019 Expedition
2019 F-150
Twin Pinzies
Post by Twin Pinzies » Fri Nov 17, 2017 11:41 am
When I replaced the clutches in both of my 710M's, the pedal feel changed a LOT! Instead of it engaging near the "top" of the pedal stroke, it engaged down near the "bottom" of the pedal stroke.
After wearing in for a few months, the pedal stroke feels much better now... more towards the middle.
63rover
Post by 63rover » Fri Nov 17, 2017 5:41 pm
I don't see it mentioned. Did you make sure the clutch fluid is topped up and that there is no air in the system?
Cheers, Clive
Post by pinzinator » Sat Nov 18, 2017 8:36 am
I was told one time that you can also just add a washer at the pivot point. I can't give exact details, but doing this accomplishes the same thing as changing the length of the rod at a fraction of the cost. Just don't drop any of the parts into the bell housing.
Post by audiocontr » Fri Nov 24, 2017 5:13 am
Hmm, not sure where to place that washer. The pin is easy enough to tack a bead onto and grind down until you can get it into gear. Honestly, the biggest challenge is finding a measuring caliper long enough. Mine is just a couple centimeters short.
1978 GMC Palm Beach
Company Cars
2019 Expedition
2019 F-150
