Tire Chains for a 712K
Posted: Sun Oct 15, 2017 11:51 am
by baycrossing
I'm looking at chains for snow/ice this winter. All my 4x trucks always got chains all around. I was about to take the same approach with the Pinz. I’ve searched tire chains in the forum and found some good info, but nothing on the subject of full or just rear chains for the 6x6. Any thoughts on that subject?
Re: Tire Chains for a 712K
Posted: Sun Oct 15, 2017 4:18 pm
by 4x4Pinz
I know I live in a desert but we go play in the snow when we can. With the 712's we find that chains on the front only works as well as any other setup in most driving conditions. That is of course when you actually need them on a 712. The 710's respond very well once fully chained.
Posted: Fri Jul 20, 2018 2:09 pm
by montieth
my 2 Pf....
While not a Pinz but I've had my M35A2 2.5 ton chained up for ice on roads down here in Georgia. Two different ice storms we had.
Chains on the front axle and rear axle worked great. The intermediate axle was left unchained. I had no stability issues and traction was great. The truck accelerated up icy hills and stopped nicely. Chains on the middle axle set would have given more traction, and if I'd been hauling a heavy load, probably ideal to add. But with a mostly empty truck, I'd say it's quite good doing just the front and rear. Spend the cost of a 3rd set of chains on chain repair tools and getting better heavier duty chains.
I had enough drive time in them that I wore the set of chains down to near worn out status on the cross links.
