but i have a another question. after reading several posts in this forum i still dont understand why many are going up to 140 weight oil when the portals were designed for 80 or 90 ?
only because of noise?
greets
There is a diference between motor oil and gear (diff, portals, hi lo case) oil......there are additives and different type of oil to put in the gears.......but Like i said, there is no race or high rpms engine in the pinzgauerrmel wrote: ↑Fri Jul 13, 2018 10:26 amValvoline's note as you posted is fairly accurate -- in spite of being a bit "Marketing".
ZDDP is a proven anti-wear additive, it is true that insufficient levels can lead to
wear and pitting in areas of high shear stress such as solid lifters. It is also true
too much ZDDP leads to corrosion. Adhesion to metal surfaces has a temperature
dependence, so there is some wear until there is some surface friction to activate
bonding.
The reason why ZDDP levels were reduced was due to antagonistic interaction with
Zinc and the Platinum in Cat converters resulting in early Cat failures. With reduced
ZDDP, the highest stress surface wear-out was solved with the use roller-lifters.
As an alternative, you could also use CJ-4 Diesel engine oil, this has proper levels
of anti-wear and likely less expensive. If anyone is using off-the shelf Oil in your
crankcase be forewarned. Below is the API guide on Oils if interested. Also an
article from Miller's Oil in the UK. I tripped over this article years ago, I also have
a picture home with Pinz lifers that look EXACTLY like the one in this article. IMHO
this is a must read -- this got me digging very deep into the topic. There's a fair
number of referred papers on the topic with repeatable lab measurements, so it's
not all self-promotional Marketing.
http://www.apicj-4.org/2009_engine_oil_guide.pdf
http://johnmaherracing.com/tech-talk/fl ... rs-part-1/
