Consensus on wheel drive lubricant?
Posted: Mon Mar 01, 2021 7:50 pm
What's the consensus on valid (preferred?) wheel drive lubricant?
- Old school 80/90W is I believe okay, but pretty thick on a cold morning. I like to call it "auto-braking".
- GL-5 Redline 75W90 seems an option, but there has been some fear expressed about it if an axle seal fails. Not sure how big that risk is.
- Something else you're running?
Right now I'm MT-90 in the transmission, dino 80/90 in the wheel drives, and moving to Redline GL-5 75W90 in the axle drives. That's three different gear lubes, and if I could settle on the same in axle drives and wheel drives, that'd cut me down to just two. The dino 80/90W is "okay", but I'd rather use something with a lower cold viscosity.
