4wd engagement
Posted: Sun Oct 02, 2022 7:22 pm
by JimmyC
My truck tends to stay in 4WD after I flip the lever back up. Anybody want to tell me me about the system before I start exploratory surgery? Any parts or tools to have on hand? Also light never comes on for 4WD.
Re: 4wd engagement
Posted: Sun Oct 02, 2022 10:45 pm
by rmel
It’s not uncommon for the lockers in any of the witches hats to be “sluggish”
disengaging. Assuming yours eventually disengages. If it does “working” it
on and off as many times as you can should improve disengagement.
Re: 4wd engagement
Posted: Sun Oct 02, 2022 11:32 pm
It's not a bad idea to flush out the 3 hydraulic lines every couple of years. The fluid may collect moisture and become thicker and jelly-like which will make engagement/disengagement sluggish.
Re: 4wd engagement
Posted: Wed Oct 12, 2022 11:11 pm
by MTPinz
When I first got my Pinz, two out of three slave cylinders were slow or 'not responding' basically due to limited use/maximum neglect. After dissecting them and flushing with fresh fluid everything is operational. Two bolts to remove the slave is all it takes to know if you need to dig deeper.
Re: 4wd engagement
Posted: Thu Oct 13, 2022 12:00 am
by ChickenPinz
I try to make it a part of every drive to engage all three locks to keep things free and tested.
Re: 4wd engagement
Posted: Sat Dec 03, 2022 12:44 pm
by Stumbler
Yes, this happens. I make it a point to exercise the systems every winter when I have snow or slippage available. The first time I engage the front diff, when I release it it will not disengage for a long time. After that, it tends to get quicker. Like they said before, probably slightly clogged lines that just need to be flushed and exercised periodically.
