Does the Pinzgauer Differential have just a fill and drain plug. Or is it similar to the Transmission that has the 3 plugs(fill, level, and drain). I have looked in several spots for this simple answer but am still coming up empty.
Differential ?
Differential ?
Justin Pitcairn
2013 Jeep Wrangler Rubicon w/
Ursa Minor J30 Camper
Instagram @pitcairnoverland
Differentials - Simple drain and fill. Took some photographs because I am a visual learner.
Supplies used. AutoZone for the Coastal Oil. Used a little Anti Seize on the treads of the plugs. Boxed end wrench is used as a cheater bar for the allen wrench. Hammer to tap the plug before loosening. 5 gallon bucket for the used oil.
Front Differential - Gear oil is being pushed up into the top fill plug. You can see the new oil coming out of the Control Plug. The bottom of the differential has the drain plug.
The Rear Differential - Upper left corner is the Fill Plug. New oil is draining out of the Control Plug. Just above the bucket is the Drain Plug.
Justin Pitcairn
differential
Thanks Justin
- totaljoint
differential
I bought some at Napa and rotate them. The one I take off I put in the bottom of the oven and when baking or some other oven related activity is going on it anneals. They are then ready for the next use.
No stress, no strain.
Re: Differential ?
Good instruction with nice visualization. Thanks!
2004 Defender 110
1979 Pinzgauer 712M
1979 Pinzgauer 712M
