Just another tip...You can often cut an O-ring to fit around a part rather than disassemble
several items just to slide an O-ring into place. Cut it, position it around the part and use a drop of superglue to join the cut ends. O-ring kits are available where you get several rolls of different diameter O-ring material and a "V" grooved block (think miter box) to let you make a nice square cut and to align the two ends for gluing.
I need two o-rings, went to NAPA and looked through their catalog and couldn't find what I needed so I bought two larger ones - cut to size and super-glued them. That was 4 years ago, still doing fine! Also did it with the front steering "ball scraper seals", two years ago and doing fine.
Saved having to pull the axles or drive wheels off.
Ring metal for axel boot.
Re: Ring metal for axel boot.
Thomas E.
Sonora, CA
712 Camper
[img][url]M:\avatar\DSCN0010%20(Custom).JPG[/url][/img]
Sonora, CA
712 Camper
I always wondered about that.Thomas-E wrote:Just another tip...You can often cut an O-ring to fit around a part rather than disassemble
