The clutch is working fine, but I notice that at highway speed it rattles a little. If I touch the pedal slightly it goes away...or pull it forward slightly. Can I adjust it so that there is no space between the arm and the stop?
Thanks!
Clutch Pedal rattle
Clutch Pedal rattle
Re: Clutch Pedal rattle
Per Repair manual page 51 fig. 96, 1mm clearance between the rod tip and the master cylinder piston.
I was hoping there might be another way....Thanks!edzz wrote:Per Repair manual page 51 fig. 96, 1mm clearance between the rod tip and the master cylinder piston.
There is. Earplugs.
I find it amazing that you can pick out individual rattles in your vehicle. I have one I cannot locate (seems to be on the right side) while moving and when I stop it stops...Hmmmmmmm.
Only reason I found it was because my foot brushed against the clutch pedal and it went away. It is fairly new though....or I think it is...krick3tt wrote:I find it amazing that you can pick out individual rattles in your vehicle. I have one I cannot locate (seems to be on the right side) while moving and when I stop it stops...Hmmmmmmm.
As for the ear plugs...well I have a pack of buds in my new centre console!!
:idea: It may also be less noticeable if you slow down to 55 – 60 mph, traveling at “Highway speeds” maybe a bit much for the Pinz.
60MPH is what I was doing...seriously . I own a Ural, so I am well versed with keeping a vehicle well within its specs and I am fine with that. I went across the US and Canada last September on my Ural and never went faster than 65MPH (downhill!). That included highways and secondaries.edzz wrote::idea: It may also be less noticeable if you slow down to 55 – 60 mph, traveling at “Highway speeds” maybe a bit much for the Pinz.
