metal angle piece behind factory angle boot
Posted: Thu Nov 07, 2013 10:30 am
I am changing out a cracked/leaking factory axle boot with a split type and when I removed the original, a small metal angle piece of metal fell out from the area where the axle casing mates to the stop ring. I previously replaced another boot and don't remember seeing this before. Can somebody please tell me what this piece might be for and the orientation of it? If I am identifying it correctly, it appears to be #21, Group 3-10-24 of the parts manual. It has a curved radius or arc on one edge and is about 2" long.
If is is needed/required, should I take apart the other side to make sure it is there?
Doug
Doug
