Clutch engagement pedal height
Rifleman
Post by Rifleman »
On my 710m the clutch engagement point seems kind of high at the top of the pedal stroke.
Is that typical?
'75 710M
Pinz710m2
Re: Clutch engagement pedal height
Post by Pinz710m2 »
The quickie test:
Try putting your Pinz in 4th gear and rev the engine a LITTLE bit and pop the clutch.
Your engine should die. If it keeps going at all, you're at the end of your clutch life.
