Huh? I'm not sure if I get your question/s right, but here goes.pinzhappy60 wrote:hi,is the steering damper prone to seizing?,as my steering is a B,in tight manouvers,dont like the idea of 60 psi in the front tyres though i guess it wont do any harm!the vibration is due for repair this summer looks quite a simple job,the welding looks simple enough,but the balancing could be another matter,does anyone know where in the uk it can be done?,anyway happy new year to you all and till next time...
The damper is more prone to losing it's resistance than to seizing, IMHO.
60 psi. To allow you to steer it? Is it like this with the front end completely jacked up off the ground? Sounds like something is tight.
Vibration, welding, balancing. Are you referring to the internal driveshaft needing to be balanced? Linden in Denver used to have someone local. Not sure in the UK
Ditto Happy New Year.
