grease points for drive train
Posted: Wed Sep 17, 2014 4:20 pm
by ziegler
Time to grease the D.T. Where exactly are these points? thanks Zig
Re: grease points for drive train
Posted: Wed Sep 17, 2014 5:36 pm
by Stekay
Only grease fittings are on the driveshaft.
Posted: Wed Sep 17, 2014 8:56 pm
by rmel
Three fittings total and don't miss them. I had to replace my shorty shaft,
one U-joint pooped out and took the shaft knuckles with it. Getting a shaft
these days ain't cheap, and you need to get it balanced too. Use a premo
Grease like Lucas.
ron
Posted: Thu Sep 18, 2014 11:59 am
by ziegler
You mentioned three grease points for the D.T. I see one on the shaft, where are the other two. Zig
Posted: Thu Sep 18, 2014 12:04 pm
There are two ends of the shaft...check the other one. Sometimes it is necessary to rotate the shaft to find them.
Posted: Thu Sep 18, 2014 12:26 pm
by Twin Pinzies
A tip for aligning your zerk(sp?) fittings on the driveshaft for the grease gun:
- Put your transfer case shifter in neutral so you can easily rotate the shaft by hand.
Posted: Thu Sep 18, 2014 6:06 pm
by Stekay
AFTER you chock the wheels!
Posted: Fri Sep 19, 2014 11:55 am
by GRCameron
One zerk in each u-joint cross and one on the spline.
Posted: Sun Sep 21, 2014 7:02 pm
by berger
There is also a grease nipple on the pintle.
Posted: Tue Feb 16, 2016 3:15 am
by HawaiiPinzgauer
These are the PDFs I scanned in from their original German Service Manual. They were front and back, so don't mind the slight discoloration.
Posted: Tue Feb 16, 2016 6:34 am
berger wrote:There is also a grease nipple on the pintle.
True. But not exactly part of the drive train, IMHO.
