The LED lights have a red (low) , blue(high
)and a white (ground)....The truck has a white (ground )and a brown and yellow wire. The ground is self explanatory, which truck wire is connected to the red?...brown or yellow. thank you
Wiring LED hedlights
Re: Wiring LED hedlights
Without a diagram to follow I would disconnect one and see if it operates the intended high or low. Just a shade tree mechanic kind of thing.
- David Dunn
Brown is ground on Euro vehicles.
White "used" to be ground on high ( house) voltage only...and black on cars.
On a Swiss Pinz the yellow is low beam and the white is high beam. Not sure about the Austrian variety.
- Hotzenplotz
colourcoding for Austrian Pinzgauers is the same:
yellow is low beam, white is high beam, and grey / red is the 5w position light inside the headlight
Albert
Albert
