View unanswered posts | View active topics It is currently Mon Jan 22, 2018 6:19 am
Reply to topic  [ 3 posts ]
 Locker Switch Operation.
Author Message
Post Locker Switch Operation.
Hi Folks. 2 out of the 4 lights for the lockers fail to illuminate when levers are thrown. Have checked the bulb filaments and connections to the holders. All clean and tight. The feed to the lamp "daisy chain" is live. I'm thinking I might have a couple of "iffy" switches down below. Question.... Before taking the pressed metal caps off to check the actual switch that lurks beneath, if I temporarily earth the single wire connection thereto, should that bring the associated lamp on ?? I'm presuming that the switch contacts are normally "open" ?
Any help/confirmation appreciated.
Mike.
Fri Jan 05, 2018 11:50 am
Profile
Post Re: Locker Switch Operation.
Yes, temporarily earthing (grounding) the single wire at each switch should turn on the associated lamp.
Sometimes the switches get a bit gummed up and need a good cleaning.
Good luck!
_________________
'72 Swiss 710M
Fri Jan 05, 2018 12:40 pm
Profile
And while your at it, put an ohm meter on the switch terminal to ground
with the locker on -- should be a very low reading.
_________________
Puller: 710K 2.7L EFI
Fri Jan 05, 2018 3:12 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
