VDO Speedometer upgrade with Telltales
Posted: Tue Jan 31, 2017 11:21 am
Both the VDO speedometer and fuel indicator (not accurate) have not been working in the 710 for a couple years. I am unable to calibrate the VDO speedometer due to some internal issue with it. So one of the things on my list is to upgrade/refine the dash panel. I had previously made a new one going away from the Pinz dash.
I have recently looked at some of the new VDO speedometers and this one caught my eye, p/n: A2C53408268-S.
Has hall effect sensor for the speed and has additional telltales: turn signal, hazards, oil pressure, and high beam. I think using those built in indicators would be pretty sweet. I have already deviated from the pinz annunciation panel so taking those wires as designated on the colored pinz wiring diagram should simply be able to input into the new gauge connector.
Has anyone had experience with this gauge?
Manual is in the link
https://www.vdo-gauges.com/instruments- ... 2-24v.html
http://www.egauges.com/120-MPH-Speedo-3 ... 8268-s.htm
