Locker Switch Operation.
cronapress
Post by cronapress » Fri Jan 05, 2018 11:50 am
Hi Folks. 2 out of the 4 lights for the lockers fail to illuminate when levers are thrown. Have checked the bulb filaments and connections to the holders. All clean and tight. The feed to the lamp "daisy chain" is live. I'm thinking I might have a couple of "iffy" switches down below. Question.... Before taking the pressed metal caps off to check the actual switch that lurks beneath, if I temporarily earth the single wire connection thereto, should that bring the associated lamp on ?? I'm presuming that the switch contacts are normally "open" ?
Any help/confirmation appreciated.
Mike.
Re: Locker Switch Operation.
Post by pcolette » Fri Jan 05, 2018 12:40 pm
Yes, temporarily earthing (grounding) the single wire at each switch should turn on the associated lamp.
Sometimes the switches get a bit gummed up and need a good cleaning.
Good luck!
2002 MB G500 (For Sale)
Post by rmel » Fri Jan 05, 2018 3:12 pm
And while your at it, put an ohm meter on the switch terminal to ground
with the locker on -- should be a very low reading.
Rescue Pinz: 73' 712M
cronapress
Post by cronapress » Fri Feb 02, 2018 4:48 am
Thanks for replies folks. Only just returned to looking at the beast after an unavoidable delay. Checked all the switches. They work ok. Someone suggested (offline) to check fluid levels in associated boxes - all correct. Since resuming work on it, ALL the locker lamps now fail to illuminate ! Am suspecting a common denominator. Connections to lamp holders ok - as are bulbs of course. A prime suspect (looking at the wiring diagram) is item #10 "Plug Connection". It is the one shown schematically adjacent to the locker switches. Question... where does this plug connector actually live ?. The wiring behind the dash is a rat's nest. Many elec. mods done by previous owner, and I don't want to poke around that area without good cause. Things are working hydraulically and mechanically. It would be nice to have the lights that say things are engaged !
Thanks as always.
Mike.
Post by rmel » Fri Feb 02, 2018 12:42 pm
Does your backup light work? That circuit goes through that connector as well (#10).
Post by Jimm391730 » Fri Feb 02, 2018 1:08 pm
All the locker lights (as well as the rest of the dash lights) go through the blackout light positions on the light switch; and those spade or ring connectors get really brittle, and break right between the ring or spade and the wire crimp so they be extremely difficult to determine where a broken wire went to! Be gentle inside the dash.
