Slow cold starter
Posted: Sun Mar 07, 2021 1:48 pm
Hey all, I'm having a fight with my starter.....
So its been a bit cold here in New England for the last few months and my 710K has been hibernating on a battery tender for the last couple months.
I decided it was time wake her up. Only a couple cranks and it was up and running as usual. Never had starting issues before.
The very next day I go to start up again.... I press the button and thunk...no start. If I continue to hold the button down it does a couple slow chugs.
I figured I left something on overnight and hooked it up to the charger overnight.
The next day.... go to start....same thing. This time I KNOW the voltage is good, voltage meeter reads 24V and each battery reads 12V.
So I continue holding down the start button and it tries, and verrrrryyyy sloooowwwwwly chugs once every few seconds and then little faster..and then it catches and it up and running.
After getting it warmed up I turn it off and try to start again. Starts right up with half a turn. I unplug the coil and try again and the starter happily turns over like it always had.
The confusing part to me is that that it started right up the day before after sitting for a couple months. Its the same temperature to with the same oil viscosity.
The batteries are reading good, but could they be lacking CCAs? Normally they don't just suddenly go bad.
Can a starter just suddenly get waker? Maybe the solenoid isn't transferring all the power the starter needs?
Battery terminals are nice and clean- connections seem tight.
I'm a bit stumped and a new starter is a good chunk of change if I don't need one.
Any help would be great!
