Samlex DC-DC converter operation
Posted: Wed Aug 18, 2021 9:53 pm
by MTPinz
My 710 came with a Samlex converter and I was curious how it was supposed to function. Having never dealt with a converter (or a 24v system before) I was wondering if there is always supposed to be 12v on the output side, or only when there is a draw.
As of now, I'm getting 24v on the input side but nothing from the 12 volt output side. The 12v side feeds a few receptacles but they are so corroded that nothing will make a connection to supply a load to check and see if it kicks on. The 15amp fuse looks fine.
Any suggestions?
- Samlex
- KIMG4118.JPG (1.65 MiB) Viewed 4611 times
- KIMG4119.JPG (1.97 MiB) Viewed 4611 times
Re: Samlex DC-DC converter operation
Posted: Wed Aug 18, 2021 11:01 pm
by rmel
With 24v in you should see 12v out — assuming the fuse is good.
Likely has given up the ghost.
Posted: Wed Aug 18, 2021 11:24 pm
by VinceAtReal4x4s
It looks a little weathered. Water may have gotten in there or enough mist/fog to corrode something. Luckily new ones are only about $100
Posted: Wed Aug 18, 2021 11:39 pm
by MTPinz
The whole truck is a bit weathered!
It's not surprising that a 20year old converter is kaput but once it stops raining (thankfully) I'll poke around a bit more and then if need be get a fresh one coming.
So 12v should be coming out with no load on it? I'll do some searching, but are these units still relevant?
Thanks gents!
Posted: Thu Aug 19, 2021 9:29 am
by rmel
Yes, 24V IN and 12V OUT -- with Zero load to full load.
The Samlex is HOT ON. If there were an overload situation
the output voltage would drop below spec limit, and a
short at the output would result in current limit and blow
the input fuse if the short persisted.
BTW Samlex converters are pretty decent BUT ---
If your going to be in areas where your converter is exposed
to Dust and Moisture then get a converter that is convection
cooled (no fan) and has a decent IP rating (Ingress Protection).
e.g. IP43 or better.
Here's a recent thread on a similar topic:
http://real4x4forums.com/PinzgauerBBS/v ... 9&start=15
Posted: Thu Aug 19, 2021 10:58 am
by Texas710
The Samlex converters are not known for lasting that long. I had to replace mine pretty quickly after getting my truck, am fixing to install my 3rd converter but to #2 taking a dump on me. Listen to Rmel when he says to stay away from one's with a fan... Lesson learned.
One of the things I learned about the Samlex, if your batteries are not charged, or failing, the converter will not work right, just FYI before you tear into this much.
Overall, easy fix with the right equipment. Spend some time thinking about whats you want to use the 12v system for and that will help you design a good replacement.
Posted: Fri Aug 20, 2021 4:48 pm
by MTPinz
Thanks guys that helps a lot. Makes sense that having a fan isn't the most desirable...I'll look into other options. I use a Victron solar controller for one of my Vanagons and haven't had any issues with it over the years so maybe I'll try one of theirs instead of the Samlex. I don't plan on using a ton of 12v stuff, just a charger for the phone really...maybe some LED driving lights...probably less than 10amps total. I'll probably just rock a BT speaker for the tunes.
Posted: Sun Aug 22, 2021 3:09 am
by VinceAtReal4x4s
A lot of the LED driving lights are multi-voltage by the way.
Posted: Wed Nov 17, 2021 2:00 pm
by MTPinz
Bringing this back around...
What's the difference between the Victron IP67 converters and the Orion style ones. The IP67, which seems like what I want in an open top rig, is waaay cheaper than the equivalent Orion counterpart. Why? What am I missing here?
https://www.victronenergy.com/dc-dc-converters
Posted: Wed Nov 17, 2021 6:24 pm
by rmel
It's a matter of the tradeoff your willing to take.
IP67 is a very high rating, Dust tight, and a degree of protection if immersed under water for a short period of time.
IP43 will prevent any particles from ingress if 1mm or larger, and resistance to water spray.
IMHO, IP43 is just fine if the unit won't be exposed to water, and as far as dust goes, being convention
cooled there's nothing to "Draw" dust inside the unit.
For more details on the IP ratings, look here
https://www.iec.ch/ip-ratings
Posted: Wed Nov 17, 2021 9:47 pm
by MTPinz
Thanks Ron, good info there. I had no idea what the specifics of the IP ratings were, or even what IP stood for honestly, other than the higher the number(s) the better the protection.
As my requirements for amperage draw are so low and insignificant, I think I'll go with the fully potted IP67 20 amp converter and see how it goes.
- 1609414511_upload_documents_1600_640_q90-ORI241220260_Orion IP67 24_12-20A (front).png (897.06 KiB) Viewed 4048 times
I'll update once it's up and running.
Posted: Fri Dec 17, 2021 12:52 am
by MTPinz
Nope, don't have a converter yet
When wiring one up, I assume you just pull power off the starter stud or is it advisable to run a separate lead all the way over direct to the batteries?
Also, should I wire up a HD relay to turn on the converter power with ignition (or the such) to minimize any voltage draw when off? Maybe this isn't even necessary.
Posted: Fri Dec 17, 2021 9:30 am
by rmel
I'd recommend that at the very least you tap off the top Battery with a in-line 20A fuse.
As far as "Switched" operation, that all depends upon how you want it to work. If you
want 12V power only on when IGN is ON then that would make sense. If on the other
hand you want the 12V devices "live" when the Battery Switch is ON then no need for
a Switched relay. And, stating the obvious, the output of the converter should drive
a Fuse box with several fuse positions.
Posted: Sat Dec 18, 2021 3:20 pm
by MTPinz
Thanks rmel, that makes sense. I'll run from the battery to the converter then just use the battery disconnect to keep it off for storage...no need to complicate things. Forgot that was an option, even though I use it all the time!
Posted: Wed Dec 22, 2021 4:23 pm
by 4x4Pinz
I first ran the Samlex converters when I got into the pinz. After replacing far too many of them I went with a few of the cheap chinese knock offs. My oldest one was installed in '06 and still going strong. I chose to tie into the power box behind the passenger seat as it is switched with the trucks main shutoff. I also chose to go with ATI style fuses in lieu of breakers simply because of ease of use and availability at the time. In todays market I might consider marine breaker assemblies just because you don't have to carry spare fuses. As time has gone by I have gone solar for all non-truck related electronic needs so the only items running through the converter now are the radio, CB, gps and some cab lighting. On all my trucks I try to size the converter to be rated twice what I believe my peak demand would be.
