Noise reduction with intercom
Posted: Wed Jun 01, 2022 1:16 am
by jan.bauwmans
Looking for payable noise reduction headsets with intercom system. Anyone has advice and/or experience with it ? Thanks
Verstuurd vanaf mijn SM-G998B met Tapatalk
Re: Noise reduction with intercom
Posted: Sun Sep 04, 2022 11:57 am
by GadgetPhreak
I have used the Rugged Radio intercom system for years. I have headsets for driver and passenger as well as one for the rear passengers (usually for the Team leader for whatever Search & Rescue team I'm hauling). I have them tied into my iCom radios so I can also use them for comms during a mission. I added the bluetooth module so my phone connects to them as well so I can pipe in music as well as take calls. Over past 4-5yrs they have performed extremely well. Highly recommend them.
Here's a few pics. First is headsets hanging on the divider panel.
- IMGP7538 (1).jpg (1020.41 KiB) Viewed 1660 times
If you look at the center console you can make out the two red buttons which is the Push To Talk to use the headsets with the radios, for intercom it's voice activated and I've had no problem dialing in the sensitivity for highway speeds in the Pinz. The controls are on the side of the center console, drivers side. I'll see if I can find a picture of them mounted.
- IMGP7519 (1).jpg (1.38 MiB) Viewed 1660 times
Posted: Sun Sep 04, 2022 12:08 pm
by GadgetPhreak
Found a picture of the intercom controls.. The control set at the back of hte console is for the Intercom.
The top contol unit with the Rugged logo is to select which radio is connected to the headset for transmission. Radio 1 is my front iCom and Radio 2 is the next one back. The toggle switch in the middle flips between the two. Neither my HAM radio nor GMRS radio is connected to the headsets.
The next control unit down is the controls for the intercom itself. The left knob is volume control and the right knob is for the VOX sensitivity. The blue light in the middle comes on when power is turned on. At the bottom middle is two 1/8" RCA jacks for a music source or cellphone source to be hard wired in. To the right of those two controls are the Mic. input plugs for my radios and you can just make out a small toggle to the right of those, which is the on-off toggle for the bluetooth input for my cell phone that I mentioned in my previous post. I have it on a toggle because I also have a Bluetooth Bazooka speaker system mounted just behind the divider. The controls for that is the round control unit on the bottom of the console, just below the mic inputs. I can power on both independently, so I don't have my phone trying to decide which to send audio to when a call comes in or music is playing.
- IMGP7491 (1).jpg (1.6 MiB) Viewed 1657 times
Posted: Sun Sep 04, 2022 2:10 pm
by ChickenPinz
Can you comment more about which model Rugged Radio product you're using and the icom connection? I'm also looking for a good solution on this, and would want to interface with a Yaesu radio to allow both intercom and HAM comms. Our team generally moves as a pack, and comms are primarily over 2m radio. No need for the headset at low-speed, but when cruising it'd be nice.
