Tachometer
blackstack
Tachometer
Post by blackstack »
I have a swiss 710m.
Electronic ignition.
I installed a VDO tachometer that does not work properly.
The tach responds to different engine speeds but never goes past the 500 rpm mark. To me it looks like it is reading a tenth of what it should read.
I have checked the dip switches and wiggled and/or cleaned all the connections to no avail.
Any ideas?
I found that some of the VDO tachs have the dip switches in reverse order. You are probably set for 8 cylinders. Instead of ON/OFF/OFF try OFF/OFF/ON. This worked for me when I had the same issues you described.
'73 Swiss 710M
tachometer
I bought a VDO tach and had to get a resister to make it operate properly, from 24v down to 12v. A friend sent me a step by step pictorial installation guide. The tach worked for awhile but would flop back and forth from 500 to 6000 rpm's I had to send it back. Now the one I have works well, I used the same guide that my friend sent both times.
It makes a difference where you tap off the input from the electronics for the dist., at least it did for me.
I also bought an electronic speedometer that died after 2000 miles. Not real happy with VDO stuff. I put the mechanical speedo back in and although it is a bit off because of the 33 inch tyres it still reads and works. I just have to do a bit of math sometimes to get the 8% discrepancy for the tyres. Figuring MPH from KM is no problem, just multiply by 6 for a reasonable guess.
That 12v VDO tach is a pile of crap :shock:
Spend the extra few bucks and get a 24v one from aircraft spruce.
Every 12v VDO tach I have installed or adjusted are not accurate.
They are usually 300-500 rpm off.
Jim,
Is there one in particular that you recommend from Aircraft Spruce?
'73 Swiss 710M
blackstack
Dippy Tach
Hey Paul !!
I reversed the dip switch settings as you suggested and.............IT'S ALIVE !!! I have to laugh because I am dumb as a sack of rocks about electricity ..I compare everything to pipes and valves and waterflow...when it didn't work when we put it in I told my son to switch the dip settings 'cause "the valve must be backwards" and he gave me hell and a bunch of electrical theory..i can't wait to rub it in.!!
I wonder if there is a table comparing speed to rpm in the various gears ..or at least in 5th?
Reads about 600 at idle so am guessing it isn't too far off.
I use a GPS for a speedometer...I was thinking of getting a programmable from VDO but maybe not what with the bad reviews
Thanks again,
Bob Gray
Good to hear you got it working. It seems that the 12v VDO tach is more responsive/accurate when truck is equiped with Pertronix module VS points.
Here is a lnk to a nice tach/hr meter.
http://www.aircraftspruce.com/catalog/i ... ometer.php
tachometer
Looking at the Aircraft Spruce tach specs, there was mention of saving settings. Does power have to be maintained, similar to a radio to save channel settings, for this feature to be effective?
When I remove the battery key all settings on the radio are gone, don't even use them.
Spec sheet says non volitile memory. So loss of power does not effect settings.
Looks like a nice unit and can handle up to 33 vdc.
ako
Re:
Post by ako »
Jim LaGuardia wrote:Good to hear you got it working. It seems that the 12v VDO tach is more responsive/accurate when truck is equiped with Pertronix module VS points.
Jim,
The link you provided is a 404. Could you please confirm which tacho you recommend out of this lot?
http://www.aircraftspruce.com/menus/in/tachometers.html
Re: Tachometer
ako
Re: Tachometer
Post by ako »
TechMOGogy wrote:Just use this one from SAV
http://www.pinzgauer.com/showdetails.ph ... no=SAV1404
I saw that one, but from above Jim said this :
Jim LaGuardia wrote:That 12v VDO tach is a pile of crap :shock:
I figured I would listen to someone who knows a lot more than me. :mrgreen:
Stekay
Re: Tachometer
Post by Stekay »
http://www.issprogauges.com/Classic-0-5 ... r85090.htm
It's nice to have a big easy to read face that's not over scaled. 5000 RPM and just twist the signal wire around the coil wire.
Re: Tachometer
Has anyone seen a 24 volt digital tach?
Re: Tachometer
I have a 50mm digital VDO 12V, but they do have a line 12/24v but they are 85mm.
http://www.vdo-instruments.com/instrume ... eters.html
