Petronix Epoxy Coil Recall
Hi Guys,
Anyone that has purchased a Pertronix Epoxy coil between January 14th 2009, and October 30th 2009 should take a look at this. Wish I had better news!
http://www.expedition-imports.com/categ ... il_recall/
We will work with our customer base to try and handle this recall by Petronix in as timely a fashion as possible.
Scott Ingham
225 Bennett Ave., Ste A
Vallejo, CA 94590
Phone: 707-643-6757
Fax: 707-643-2998
Scott Ingham
Vallejo, CA 94590
Phone: 707-643-6757
Fax: 707-643-2998
Should I worry?
Should I worry? My PZIGCONV kit came from you in September of 2008, it looks the same as those described in this recall however is not in the date range indicated.
Thanks for posting this information.
Ed
edit
photos added
Ed
edit
photos added
Hi Ed,
Can you post up a picture and or send it to me via email or your coil. Also drop me a line off-line so I can look your order up.
Scott
Scott
Vallejo, California
Vallejo, California
pictures added to my prior postExpeditionImports wrote:Hi Ed,
Can you post up a picture ....
Scott
Thanks Ed
Hi Ed,
I'm going off of the Pertronix supplied date range from when things changed on their end. I will do a little investigating on this end. Please forward me your order number or name via PM so I can pull the batch information from your order. I can't seem to find an "Ed" that purchased in September of 2008, unless you happen to be Eduardo Acosta which I don't think is the case.
Scott Ingham
Scott Ingham
Vallejo, California
Vallejo, California
- totaljoint
Hi Scott:
This "Ed" just had the petronix conversion done at Goatwerks on the 712. a couople of weeks or so ago....Does this apply to me?
Thanks for letting us know about this!!
Ed Eissmann
totaljoint@hotmail.com
Ed Eissmann
It is pretty much a given that if you purchased an ignition conversion from us since January 2009, you WILL HAVE A COIL THAT IS RECALLED.
Scott
Scott
Vallejo, California
Vallejo, California
Update:
Pertronix has revised their recall dates to cover all "enclosed can" style of Epoxy coils. The dates applicable to this recall have expanded to cover coils distributed between May 2008, to October 30, 2009.
I will update as soon as we are shipping the replacement coils.
Scott Ingham
Expedition Imports Corp.
Scott Ingham
Vallejo, California
Vallejo, California
PERTRONIX RECALL COILS ARE SHIPPING
Hi Guys,
Replacement Pertronix Coils are shipping. Due to the extent of the recall we have setup the recall on our website in order to track/facilitate the swap out. We are handling close to 200 recall transactions, so please use the store to facilitate this as it will make the process much easier for everyone involved.
If you are one of our customers that the warranty covers, please "purchase" this item on the store. The swap out is FREE OF CHARGE.
http://www.expedition-imports.com/produ ... ssing.html
If you are trying to determine if this applies to you, please view the recall information here:
Scott Ingham
Scott Ingham
Vallejo, California
Vallejo, California
