Best Power Inverter?
rockymtnshepherds
Post by rockymtnshepherds »
I am sure this has been discussed at length but can someone tell me the best 24-12 volt power inverter they know of for the $$$? Thanks for your replies.
Thomas-E
24 to 12 volt
Post by Thomas-E »
I use a Solar Converters Battery Equalizer and am very happy with it,
been using it since 2006.
They have other neat items such as a 24 too 12 volt battery charger which I am installing in my camper (all 12 volt in it)
Check out the following link on the Real 4x4 Pinzgauer forum, it's in the "archive section".
http://real4x4forums.com/PinzgauerBBS/v ... php?p=5668
Note the use of relays to completely remove it whem the battery switch is off. Inexpensive relays can be obtained from
www.allelectronics.com
Best of luck in your search!
Thomas E.
Sonora, CA
712 Camper
acebee
get a good battery equalizer instead!
Post by acebee »
the best money can buy ? last word.. Vanner Voltmaster..bar none!
just check the entities that have them on as the vendor!
one is being sold..
http://cgi.ebay.com/ebaymotors/Vanner-6 ... 5004r29724
standard disclaimers apply..
Re: 24 to 12 volt
Thomas-E wrote:I use a Solar Converters Battery Equalizer and am very happy with it,
Regardless what it says on their website, these units ship from Canada FAST!!! They are built to order.
rockymtnshepherds
The link does not work to the "Solar" inverter Archive link? Thanks for the feedback.
Thomas-E
12 Volts
Post by Thomas-E »
I apologize about the link.... I had saved it some time ago and just didn't check it again. :oops:
Here's another one that the shows a hookup for the Solar Equalizer, just copy and paste into your browser
http://f1.grp.yahoofs.com/v1/oNKbS-dbtj ... ire_02.jpg
This schematic adds two relays in the equalizer lines to prevent a small but constant drain when the engine is off.
Take some time to see what other pinzers have used, there have been complaints about some 24 to 12 volt converters not lasting long.
Thomas E.
Sonora, CA
712 Camper
lito
Post by lito »
that link looks broken as well...
just a good example of a bad example...
best power inverter
Check this place...
www.24voltproducts.com
be prepared for some sticker shock, but some stuff is on sale.
Morris
best power inverter
Check this place...
Morris
McCall Pinz
Post by McCall Pinz »
I don't know if they're the best, but I'm running one of the 20 amp Solar Converters too. Northern Arizona Wind and Sun had the best price at the time-
http://store.solar-electric.com/volcon.html
Definitely wire it with the relays or it will drain the batteries every week and Optimas don't like that. Fortunately Optimas have a good warranty
:oops:
