Where is park brake switch?
My parkbrake/handbrake light doesn't come on when I park the Pinz - I've tested the bulb - where is the actual switch so I can check from there?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Where is my parkbrake switch
The parking brake switch is under the left rear corner of the truck and is operated by the swinging arm. Just follow the hand bake cable back and you'll find it.
Re: Where is park brake switch?
Is there is a non-steyr part for the hand brake switch at the rear? I believe mine is shot.
The original is available at SAV
http://www.pinzgauer.com/showdetails.ph ... 111850350/
Thanks! I found it after I posted . I am hoping EI has one because I want to order the ignition conversion, sans petronix.4x4Pinz wrote:The original is available at SAV
