Hella Light Installation
Posted: Tue Apr 19, 2011 2:50 pm
by jrcotner
The old Bosch headlights are getting a little blurry, so I decided to install some nice Hella headlamps. I removed the old lights, and found two extra lugs on them with spring connectors: one with two white wires, the other with a single grey wire. Not knowing what to do with the spare wires, I wrapped them in electrical tape for the moment, connected the lights, and found the lamps only burned at about 1/3 illumination. Clearly the white and grey are important, but where should they be connected? I checked around the site but couldn't find out about wiring these Hella lights.
Re: Hella Light Installation
Posted: Thu Dec 31, 2015 12:54 am
by Rangefinder
Hi
I just posted a question like yours some what
I did not see an answer to your question
Did you get one and could you share
please and thanks
dale
Posted: Thu Dec 31, 2015 5:15 am
by Profpinz
This link to a coloured wiring diagram on Robi's Pinzgauer Forum may help.
http://pinzforum.kiruna.de/viewtopic.php?f=3&t=9135
Posted: Thu Dec 31, 2015 8:38 am
Here's a link to the colored schematic on THIS forum:
http://real4x4forums.com/PinzgauerBBS/v ... =14&t=8985 (I think they both show the schiz PC made.)
According to the schematic, there are three hot leads going to each headlight assembly: Hi beam, Lo beam, and Parking light. It's chassis grounded.
You'll only want the Hi beam and Lo beam hot leads to feed the new bulbs, and ground the common lead from the bulb. The lead for the Parking light will not be used.
Posted: Thu Dec 31, 2015 10:48 am
by Rangefinder
Thank you
Dale
