can you jumpstart a pinz with another pinz ?
norcal pinz
Post by norcal pinz »
Hi guys my K battery went dead can i jump start it with another pinzgauer in normal fashion i already know not to jump start it with a regular 12 V system
thanks Guys !
710M 1972
710k 1974
Re: can you jumpstart a pinz with another pinz ?
Yes, 24v+ to 24v+, 24v- to 24v-
norcal pinz
so no disconnecting of wires ? just pos+ to pos+ neg- to neg-
and im assuming a normal set of jumper cables will work ??
710M 1972
710k 1974
There are also threads on this forum on how to jump a 24v ( dual battery) system from a 12v system... it just takes safety precautions, but not difficult
norcal pinz
Thank you Guys !!!! i always like to double check here before i fry something . :mrgreen:
710M 1972
710k 1974
norcal pinz wrote: and im assuming a normal set of jumper cables will work ??
Yes
spandit
Post by spandit »
I keep a laminated copy of the 12V jumping instructions in the vehicle - had to use it in anger on more than one occasion!
I suppose being 24V means that jumping from a 24V vehicle means that the leads you use can be thinner (or rather, there is more safety margin)?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
spandit wrote:I suppose being 24V means that jumping from a 24V vehicle means that the leads you use can be thinner (or rather, there is more safety margin)?
Not really. Two group 27's in series = same amp's as one, just twice the voltage, the amp draw determins the wire guage not the voltage.
True, but the Pinz electrical system does not pull twice the power of a "normal" 12V vehicle; it is equivalent. So the starter current would be half of what you might expect from a 12V vehicle. This is one reason why the 24V system is considered better; you can realistically draw the batteries down further and still get a Pinz to start because the draw on the batteries is less.
BUT, jumpering a discharged 24V set of batteries will pull MORE current through the cables then could happen with a 12V battery. Remember that 24 volts has twice the energy! Treat it with respect.
norcal pinz
Turns out i didn't even need to jump start the "K" afterall, there was just enough battery left i shot some starter fluid down the breather hose and she started right up.
710M 1972
710k 1974
