I'm looking at at '76 Pinz that apparently has a bad converter. My question is this:
What can't a 12v accessory buss be set up by simply tapping off ONE of the two 12v batteries?
Thanks for any info on this,
24v to 12v converter. Is it really necessary?
'76 710K
'76 710K
Re: 24v to 12v converter. Is it really necessary?
mm58 wrote:I'm looking at at '76 Pinz that apparently has a bad converter. My question is this:
Hi Mike.
I haven't gone this route with my Pinz, but I played with 24v/12v on my Iltis. I am sure more experienced guys will jump in, but in my research on the matter then, the main reason for not tapping only one of the batteries for 12v is you will shorten the life of the one battery. The batteries are supposed to be in series, so when one is being tapped, the other has to work harder to compensate shortening its life. It is worth getting a converter/balancer to ensure this does not happen.
That's a very good explanation, thanks!
'76 710K
'76 710K
- David Dunn
This topic has been covered a thousand times, do a search on the topic, but shortening the batteries life is the main problem... On a 710/12 Pinz, you do not run any leads back to the negative side of the battery. again, it has been covered many times
