Flasher Relay
ScottishPinz
Flasher Relay
Post by ScottishPinz » Sun Oct 07, 2012 2:02 am
OK so I have a new Flasher Relay to sort out my slow indicators, but question is, where is the relay located so I can change it over.
Re: Flasher Relay
Post by krick3tt » Sun Oct 07, 2012 6:33 am
My flasher relay is located above the foot brake reservoir on the front left at the flat panel.
CentAr712
Re: Flasher Relay
Post by CentAr712 » Sun Oct 07, 2012 1:41 pm
I just changed mine last week; the ones at SAV are as cheap as I could find and they work great. In the pic on their site it looks like a cheap generic part, but when you get it, it actually looks like a good quality name brand component. I cut the metal bracket off the old stock flasher unit and modified it to hold the new one. The flasher is the aluminum cylinder near the emergency flasher switch.
Chris.
https://www.supanik.com/pinz
ScottishPinz
Re: Flasher Relay
Post by ScottishPinz » Tue Oct 09, 2012 7:43 am
Fitted new flasher relay. Bit different as it doesn't have an earth connection to the body. All works fine except the light on the dash doesn't flash very brightly now!
dbixby001
Re: Flasher Relay
Post by dbixby001 » Sun Feb 25, 2018 4:13 pm
Is this the correct replacement for my original 91PMK 3+1x20W 24V flasher relay? https://www.pinzgauer.com/showdetails.p ... no=SAV1430
If so, what is the proper way to install the new flasher unit? The old one I have had two separate bolts connected to separate wires. This just looks like it has the one hole for one bolt. Please advise.
Re: Flasher Relay
Post by TechMOGogy » Sun Feb 25, 2018 4:28 pm
http://www.real4x4forums.com/PinzgauerB ... =14&t=6089
If you don’t want to drill a new hole higher up you can use the existing right hole from old flasher but it will be a bit lower
bbolander
Re: Flasher Relay
Post by bbolander » Sun Feb 25, 2018 5:48 pm
I managed to fit mine to the top hole, wasn't easy.
IMG_1656 copy.jpg (526.54 KiB) Viewed 1061 times
