gas guage ground ?
norcal pinz
gas guage ground ?
Post by norcal pinz » Wed Apr 10, 2013 12:43 am
when i turn on the lights or the wipers the gas gauge moves to full is the ground an issue here ?
710M 1972
710K 1973
Re: gas guage ground ?
Post by undysworld » Wed Apr 10, 2013 7:08 am
IIRC, power runs to the meter, then grounds through the sending unit. If you disconnect the wire at the sender and ground it, the meter should peg. Something sounds fishy in the wiring. I'd get a volt meter and check to see what's going on there.
Post by edzz » Wed Apr 10, 2013 4:02 pm
