Fuel Gauge and Sender info
compunerdy
Post by compunerdy »
Was messing around with my fuel gauge and sender today as I am installing a digital gauge and figured I would share some info I found.
First off my VDO sender specs..
5 ohms Full
87 ohms Empty
Mounting Flange is 2.8" OD
Mounting holes on 2-1/8" diameter (54mm) and has 5 holes.
13" Long from flange
1.58" tube diameter
I (roughly) measured from the top of the tank to the bottom and got 17". After doing some research I found this tube sender which is 15.75" long.
http://www.vdo-instruments.com/fluid-le ... ength.html
From reading other sites it looks to be a 90-0 (90 full 0 empty as far as I can tell) but is used with VDO adjustable gauges such as this 24v one.
http://www.vdo-instruments.com/instrume ... ction.html
It looks to me that if you wanted to change the sender to the one listed (around $60) and change to the gauge listed (around $30) you could have a more accurate fuel reading (deeper in the tank). I know I read some of you have adjustable ones already so you would not need to change the gauge (maybe).
I stuck a tube inside to see at what point the sender would hit the pickup tube and it was around 14.5". I am not sure if you can massage the pickup tube to the side and out of the way yet or not but they do have a 14.5" (and many other length) sender as well..
Tim
1975 710K
compunerdy
Re: Fuel Gauge and Sender info
Found some more info..
In the parts book it lists the fuel sender as VDO 224.817/008/002 so I googled that and there was one listing for a german (I think) PDF from VDO.
This shows the sender as 13" long (331mm) a with a range of 2.2 ohms full to 84.4 ohms empty.
Tim
1975 710K
