Voltage at coil.
Posted: Sat Dec 28, 2013 2:42 am
by cronapress
In trying to get to grips with a bigger problem, may I ask a simple question (from a simple soul!)? With the ignition turned on - but not cranking the engine, what should I expect to measure voltagewise twixt the +ve low tension connector on the coil and ground? I'm getting just over NINE volts. Batteries are fine and I'm getting 24v in other departments. I smell a large furry rodent here. Petronix fitted by prev. owner. As I don't have a team of highly trained white mice with mirrors, I haven't had a poke at the Ballast Resistor - yet! Maybe barking up the wrong tree there?
Thanks.
Mike. Scotland.
Re: Voltage at coil.
Posted: Sat Dec 28, 2013 10:04 am
by blackstack
if you do a search for "electronic ignition trouble" you will find a post that says the voltage should be 16 to 20 volts positive terminal to ground. Nobody contested that so i assume it is correct ..mine is 19
Posted: Sat Dec 28, 2013 10:23 am
by cronapress
Many thanks indeed blackstack for your help. Much appreciated! I'm definitely deficient in the volts dept. by the sound of it.
Mike.
Posted: Tue Dec 31, 2013 8:43 pm
The voltage at the positive coil terminal will vary, depending on whether the points are closed or open (with the engine off). I'm not certain what to expect with a pertronix, either -- with the engine not running.
When idling, the voltage should read in the 16-19V range.
