24 volt plug ID
Pinz710m2
Re: 24 volt plug ID
Post by Pinz710m2 »
It's not like Colorado here. In the summer it gets hotter than the desert (i've lived in both high and low deserts) without the advantage of low humidity. I've lived in the desert, in the mountains, and a few places in-between, and frankly, the summers here are too humid/hot to be comfortable without a/c. An exhaust fan would be nice when the top is on. (I can't leave the top off all the time, crime in Chicago is terrible too. It would get stolen pretty fast. I have to use a club, remove the battery cutoff, and I'll probably install locks too.
Re: 24 volt plug ID
Best to exhaust the hot air at the top of the cab. You can get an ~4" opening in the center of the rollbar, and put an exhaust fan in there to blow the hot air out.
Pinz710m2
Re: 24 volt plug ID
Post by Pinz710m2 »
We get rain too.
Re: 24 volt plug ID
Add a rain cap. But it's probably not too hot when its raining, right?
Re: 24 volt plug ID
Pinz710m2 wrote:We get rain too.
Looks like you have it all figured out already but here is another option that member ScottishPinz used on his 710k
Similar examples:
http://www.amazon.com/Solar-Panel-Venti ... B000JT0O30
http://www.etrailer.com/Enclosed-Traile ... 45001.html
3-24-2014 10-45-26 AM.jpg (73.69 KiB) Viewed 2057 times
Pinz710m2
Re: 24 volt plug ID
Post by Pinz710m2 »
Hey, that's pretty sharp. It has the same dimensions as the arial mount?
