My front brakes began to squeal the other day. When I removed the drums to inspect them, I found a very faint groove in the passenger side drum. About the same feel as a hair on the drum. The pads were fine. Is there an acceptable amount of grooving, or does any amount require a trip to the machine shop for turning? If there is an acceptable amount, what is the maximum allowable depth?
Brake Drum Groove
Brake Drum Groove
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
John,
When in doubt, assume that not everyone can be wrong, so you must be right! Don't feel bad just because nobody answered this earlier. Speaking personally, I assumed others more wise than I would put in their opinions.
I don't have my manuals in front of me, but I vaguely remember somewhere seeing the specs in them. A "hair" groove doesn't sound that bad to me. But, any local brake shop could likely look it over for you and give you a more professional opinion. I believe the manual's specs covered maximum I.D. of the drums in the event of turning them on a lathe.
Sorry I can't be more specific.
Paul
Paul
Re: Brake Drum Groove
I am trying to find the drum specs on the site, and this is the closest my search has come.
I need to have my drums turned and I was asked what the allowable tolerances were for the drums, is there a thread that has this info?
If not what I would really appreciate the information?
Please add your location to your profile. Have you no manuals? Here are the numbers you need.
- brake.jpg (98.94 KiB) Viewed 3935 times
Awesome thank you
