View unanswered posts | View active topics It is currently Tue Aug 22, 2017 2:22 pm
Reply to topic  [ 6 posts ]
 Wheel stud replacement
Author Message
Post Wheel stud replacement
Has anyone changed there wheel studs out for longer ones?
How hard was it?
Any tips on doing it?
Thanks!
Mon Jan 11, 2016 2:08 pm
Profile
Post Re: Wheel stud replacement
I would also like to change mine with the recent aftermarket wheel install. Any tips and sources for 14mm x 1.5 and length of studs appreciated
Wed Jan 13, 2016 3:28 pm
Profile
Google "m14x1.5 wheel studs" and it will belch forth a host of options. You might want to purchase an original and make a few measurements to be sure the knurl is the correct size. http://www.pinzgauer.com/showdetails.php?cat=pinzgauer&partno=7101343241/
_________________
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Thu Jan 14, 2016 2:01 pm
Profile
Looking for information on longer wheel studs. I have aftermarket aluminum wheels that don't engage enough threads. Also do you have to remove axle to replace the studs or the be pressed off while on the vehicle?
Can anyone provide measurement for the length of stock stud?
Thanks in advance. Thanks
Wed May 17, 2017 1:55 pm
Profile
Chris - I have a bunch of wheel studs, check when you come over this weekend. If they are what you are looking for you are welcome to them. I think there's enough there for all of your wheels. I also have a set of TD tail lights you are welcome to if you want them, I switched to round LED.
_________________
King County Search & Rescue | WA Regional Special Vehicles Unit
Follow my build: http://www.facebook.com/sarpinz
Wed May 17, 2017 4:53 pm
Profile WWW
I spent a lot of time trying to locate longer studs found some dodge 3/4 ton that would probably work. The dodge one are a few thounds smaller in the serrated area so I was a little concerned. Then I found some Gorilla extended lug nuts. Problem using these was the clearance of the wheel holes is .609 and I needed .625 for the entended nut to go in. I called Trail Ready Wheels this morning at 0730 and actually got someone to answer. He said drilling out wheel to .625 5/8 inch was not uncommon. After doing that I did test fit with chrome nuts. Hopefully that solves the tearing of the lug nut threads due to lack of engagement.
Mon Jun 12, 2017 10:36 am
Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
