front coil spings...
waterdog
Paraguay
Post by waterdog » Wed Mar 13, 2019 2:20 pm
hello .. does anybody know if a TD Front coil springs are a direct replacement for a 710 ????
any experiences???
1985 710MS
1985 712MK
Re: front coil spings...
Post by pcolette » Wed Mar 13, 2019 3:05 pm
They each use different part numbers.
7101543921 for Series 1 (Gas), 7581540421 for Series 2 (TD)
2002 MB G500 (For Sale)
David Dunn
Post by David Dunn » Thu Mar 14, 2019 12:21 am
TD front springs will fit the 710/12, BUT the 716/18 are handling more weight in front with the diesel , auto box (in many cases) plus the radiator and additional cooling system weight. The TD's front suspension had more spring/support pins combos because of additional accessories ( like winch, etc..)
Attached are the factory spring/support pins available from the factory
5th TA 162.pdf
(616.04 KiB) Downloaded 142 times
